454 ss
Old 09-03-2009 | 03:19 AM
454navyss's Avatar
i believe on a stock 454ss timing should be set around 6-8 degrees, mine had the mods in my sig and i had mine set at 14-16 degrees
Old 09-03-2009 | 03:28 AM
00Silv4.8's Avatar
start with spark (coil) my buddies car was doing the same thing for awhile till it stopped starting, found a hole in the coil. Just saying. And then try fuel pressure. If it wasnt getting enough of either obviously it wouldnt start but with a coil having issues it'll run just like
Old 09-05-2009 | 05:59 PM
peterls1's Avatar
Thanks for all the ideas we r goin through all them now, not sure how to check the compression though Ill keep updated if all is done and still problems thanks again guys.
Old 09-05-2009 | 06:38 PM
peterls1's Avatar
Um might be dumb ? but how do u check the fuel pressure on this truck being a TBI and all, i know its pumping fuel we checked the filter and while it was off turn the key and it was shootin fuel pretty good.
Old 09-06-2009 | 08:44 AM
BigMone's Avatar
Its a little different on the TBI stuff to check presssure was the fuel filter stopped up?
Old 09-06-2009 | 09:32 AM
Dock Rocker's Avatar
I would reccomend that you go buy a gauge from jegs or a local speed shop and a fitting. The fitting will screw in line at your TBI and you connect the fuel line to the fitting. Make sure that you get a low pressure gauge for tbi.
Old 09-06-2009 | 11:57 AM
YenkoST's Avatar
You can check it too ways...like Dock mentioned or get a fitting that replaces the fuel filter for a moment and then start the truck...check the psi. You will not have a filter on the fuel during this so...least amount of time would be better so make sure your engine is warmed up already before doing this method.
To check compression, again, make sure your engine is warmed up. Get a compression testing tool...and one by one, you'll take out the spark plugs and insert the tool into the spark plug hole...have someone spin the engine over (pull the coil wire off the distributor and the fuel fuse to make sure the engine doesn't start) and watch the gauge and write down what it peaks to.
dragpac
12-08-2015 05:48 AM
Raylar Engineering
08-26-2015 10:36 PM
Bret Kepner
07-12-2006 08:07 AM
Quick Reply: 454 ss
