'71 LWB C10 in DD mode now!
#41
Hey just found your build very nice i am in the process of putting a 5.3 in my 72 chevy 4 wheel drive i am trying to round up all the parts before i start the build but one think i am lacking is the throttle cable i was just wondering what you used and how did it work with the factory pedal
#46
I would like more info about your wire harness and where you put the pcm? I know you said the wire harness was from a van. What are the three relay for? Can take some more engine bay pictures. Thanks
#47
I got the DIY Current Performance harness. Mounted the PCM on the fender.
Relays are for A/C (which I am not using), FANS, and Fuel Pump.
If you need other pictures just ask.
black box with white sticker is the Cable X box I use to run the stock speedo.
#48
Thanks for info. I was checking diy current web sit and there a lot good stuff there. The wire harness are pretty spendy but looks like good stuff. Thanks for the pic's and when chance check my build thread.
