89 c1500 headlamp conversion
Hello, I`m not sure if this has been posted (unable to find a thread on it). I have a `89 c1500 with the 4 sealed beam headlights and I would like to put in the composite style . If I were to order a set of composite head light assemblies would I need to do any modifacations or build any mounting brackets or will they bolt in? Thank you in advance for the help
They go is in the same location as stock and use the same hardware to mount. You might have to trim the back of the radiator support brace behind the headlight with some tin snips to allow the new housing to fit properly.
Alvin@PCMofNC
09-03-2015 06:38 AM
89, beam, c1500, composite, conversion, conversions, converstion, headlamp, headlamps, headlight, headlights, kit, pickup, reference, sealed, seam
