alternator on 00 5.3
my 5.3 alternator acting like its not working...but it pass the test at o'reilys today...so wth? its in a 91 silverado,i have a feeling it the stock pig tail that the problem....or someone can that has done the swap can lend a pic or two...thanks
Did you ever find out the problem?I will be putting a 5.3 in a 92 chevy pickup 2wd and i am trying to find out how to wire up the alternator correctly for the gauge and function but can seem to find the right answers.
I had an alternator that was acting up, wild spikes in voltage and it would not charge. took it to auto zone and it passed. so i went home and checked everything i could think of to no avail. So i took a screwdriver and a hammer drove the screwdriver into its heart a couple times(nothing to noticeable) took it back to auto zone and what do you know it failed that time. got a new one on warranty, and all my problems were solved
the brushes in the alternator are probably wearing out and making intermittent contact...the problem will progressively get worse until complete failure. also go through the basics such as checking all your connections, make sure everything is clean and tight etc.
Well I finally fixed my alternator problem....got an alternator from the shop out if an 98 zerria with 4.3 fitted just right in the 5.3 bracket...hooked the wires up n bam 14 volts
