How do i get rear slider out of OBS ?
Hey guys i found a local truck being parted out and could use the rear slider to replace mine. Problem is ive never removed one from this body style. Its a 95 . It appears to be glued in, but didnt want to ruin anything till i got some oppinions on how to remove it.
I had a local glass company pull the rear glass out of my 95. It is glued in just like the front windshield. The guy who took it out had a vibrating type cutter that worked awesome. If you have ever broken a bone and had a cast cut off of you, the cutter was similar to the cutter to remove a cast. I don't know how else you could easily remove it without this tool.
GrooveCityZ71
08-31-2015 12:05 PM
350SS
07-11-2015 12:34 PM
