msd 6010 tuning
wish i could help. i'll be playing with the 6010/6012 tuning here soon. can't wait! from what i've READ (not experienced) guys just tend to set the idle timing in to where it idles best, then ramps it anywyere from 29-36* of timing by 1800-2000 rpm. simple enough! some trucks will idle best with 20* others will idle better with 30*. just give the motor what it wants.
as for the starting range i also think you want to play with it depending on the combo. start at really low timing and ramp it to your idle rpm/timing. LS1tech has a carb section with some good stickies. phantom is a good source too
If you're calling a holley a POS and going to fix it with an eldebrock, I would suggest you do lots more reading.
GXPJAY
02-13-2022 09:15 AM
