Reading Plugs...
Reading Plugs...
Reading Plugs....
alrighty now, so i posted up a thing in a diff. forum about my tranny blowing up. Well i had sprayed the truck for the first time 2 weeks ago, and it held up well.
I just checked the plugs today. Not sure how to read them.
Tried to get some good pics, but my camera sucks...
Normal
Light brown, tan or grey firing end. A good indicator that the plug is functioning correctly and general engine conditions are good.
Dry and wet fouling
Fouling, either dry (top - matt black, sooty) or wet (bottom - gloss black, sticky),
Can be caused by many different conditions. Carbon deposits build up when the plug fails to fire correctly and burn them off. Air/fuel mixture too rich, choke stuck on, electrical problem, extended periods of low speed driving, plug heat range too cold. All should be investigated
Overheating
When overheating occurs, deposits which have accumulated on the insulator tip may melt and give the tip a glazed appearance Possible causes are overadvanced ignition timing, air/fuel mixture too lean, water or oil level too low, plugs not fitted (tightened) correctly, plug heat range too hot.
Yours look normal to me.
Dry and wet fouling
Overheating
Truck Sponsor
Kind of hard to tell in those pics without seeing the base of the porcelain,also hard to see the ground strap clearly in those pics.The ground strap is what tells you if the plug is to cold or hot.
Read this and you will get a much better understanding on how to properly read your spark plugs.
IMo,this is very important
http://www.dragstuff.com/techarticle...ark-plugs.html
calsdad
06-14-2023 11:07 PM
