some pics of my 71 swb
Old 01-30-2007, 12:43 PM
Farmtruck's Avatar
Default some pics of my 71 swb
Old 01-30-2007, 12:45 PM
Farmtruck's Avatar
here's some of the cage
Old 01-30-2007, 01:36 PM
LIL SS's Avatar
Looks like a great runner
What kind of 60's are you pulling on the average and what's your best?
Mind explaining your rear suspension setup. Being 60-72 is pretty much the same, it looks like you have a handle on it.
My thoughts were to:
Keep stock truck Arms
Buy Hal adjustable coil overs and remove stock springs/shocks
Make an adjustable PH bar
But I would like to hear what you have done. TIA
Shaun
EDIT: I found some info in another link
Originally Posted by Farmtruck
71 swb chevy weighs 4050lbs with a cage and me in it. with stock coil overs and shocks, the best 60' is a 1.463, and i run 15x8" rally wheel with a 29.5x10.5W slick
https://www.performancetrucks.net/fo...87#post3546087
Very impressive. What does it 60' off the bottle?
Old 01-30-2007, 01:48 PM
LIL SS's Avatar
Little more info.. Sweet ride
https://www.performancetrucks.net/fo...d.php?t=384424
Old 01-30-2007, 02:42 PM
Farmtruck's Avatar
i think my best 60' on the motor was 1.68, and a 1.70 being average for it which sucks. On the bottle the best 60' is a 1.463 which i think can and will get better.The rear of the truck still retains all the stock suspension it came from the factory with,but a buddy of mine has made some upper control arms for the back that are adjustable,and he said they helped his truck alot so i'm thinking about buying a pair. Another thing that i'm going to do is buy a set of aluminum rims for it,and that will take alittle weight off. i hope this helps
Kiah
Old 01-30-2007, 02:51 PM
LIL SS's Avatar
So adding UCA's making it in to more of a ladder bar or seperate mountng points making it more like a 4 link?
One of my thoughts was to cut the mounts loose from the rear so pinion could be changes and add a 3rd link up top. But if you cutting sub 1.5 60's I think I'll just put the shock spring combo in with the adjustable PH bar and call it a day.
How high is the stall flashing on the bottle?
Old 01-30-2007, 03:11 PM
Farmtruck's Avatar
my truck has upper control arms and coil springs from the factory, all i'm doing is making the upper control arm's adjustable kinda like someone putting adjustable UCA's on a G-body car,and the 1.463 is only when i hit the button,and the converter is a 3500 Neal Chance bolt together,you can have the stall changed in it,i think it stalls up to about 2600 before it starts wanting to push through the brakes
Old 01-30-2007, 03:48 PM
chevyguy7802's Avatar
Nice! Love the pictures,What do you got going on up under the hood?
Old 01-30-2007, 03:51 PM
Farmtruck's Avatar
it's a 450hp 502 crate motor with some mods
Old 01-31-2007, 12:36 AM
Chevy_Truck_Man's Avatar
Jesus Christ
Quick Reply: some pics of my 71 swb
