Syclone, Operation: "Quick Brick"
#44
Are you going to be running stock injectors?
It looks like it in that pic.
I've been lurking on your build both here and syty.net since I find it interesting to see how fast you'll go. I find it interesting, because you're not doing the norm, like just going straight to vortecs/bowties, aftermarket hot parts, an 80E, or just a V8 swap. It seems like a nice budget build with parts that'll work well together.
Do you have any pics of the heads, and what port work was done to them?
![Bomb](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_bomb.gif)
#45
30 over stock block, 4bolt splayed mains, h-beam rods, TRW pistons, stock crank, heads are L35 ported by Waller with 2.02 and 1.60 valves, 1.6 pro mag rockers, 875 lifters, pro mag pushrods, custom cam, 65# high imp injectors (would have needed 75 or 83, but i have meth so 65's are ok), AlkyControl meth injection, 72mm turbo from Precision, Code$59.
![](http://www.pittspeed.com/uploaded/04.14.08-15.jpg)
![](http://www.pittspeed.com/uploaded/04.14.08-20.jpg)
![](http://www.pittspeed.com/uploaded/04.14.08-22.jpg)
![](http://www.pittspeed.com/uploaded/04.14.08-29.jpg)
#47
came extremely close to it running tonight.
had a bad ground wire, and the battery was grounding through the O2 sensors, and thin ground straps.
so i need to ground the engine a little better. it cranked fine, had no leaks, good fuel pressure, just a matter of better grounds.
#48
Looks like it's coming along nicely. Those damn grounds will get you everytime. People tell me that I over ground....I tell them not possible..lol. You're almost there.
#49
