Weight of a '98?
Old 01-09-2011, 01:47 AM
swift700's Avatar
Default Weight of a '98?
Hi guys, I'm looking for the approximate weight of a '98 RCSB 4x4? Thanks.
Old 01-09-2011, 09:35 PM
Swerve7rpm2000's Avatar
ill throw an educated guess out there of 5,500-5,750lbs
Old 01-09-2011, 10:14 PM
Baltimore Whore
Mangled03gmc's Avatar
Where are you getting these numbers at?? The obs trucks weight less then the nbs.nnbs trucks do
Old 01-09-2011, 10:37 PM
ok so make your guess then
Old 01-09-2011, 10:48 PM
Baltimore Whore
4200..
Old 01-09-2011, 10:49 PM
13 Second Truck Club
DV2000NJ's Avatar
I'd say somewhere in the 4500 lb. range. My truck weighs about 4900 with a quarter tank of gas, and it's newer, and an ext. cab.
Old 01-09-2011, 10:57 PM
4200..
Im comfused u said the obs were lighter, my truck (obs) is a rcswb stepside and its 5k with me in its a 2wd, its been a long time since i weighed it but it was either 4000 or 5000 with my weight deducted, guess i need to get back on the scales since i ripped alot of stuff out..... so the newer trucks are lighter or heavier?
Old 01-09-2011, 11:03 PM
Baltimore Whore
The obs trucks are lighter then nbs or nnbs trucks.. I think the v6 rcsb trucks are like 3900 or so..
Old 01-09-2011, 11:16 PM
ill post mine when i re-weigh it then getting old and forgetting crap
Old 01-09-2011, 11:19 PM
Baltimore Whore
A section from here http://www.ehow.com/list_7634078_199...ado-specs.html
The curb weight of the truck is as low as 3,801 lbs. for the base model with a manual transmission. The curb weight gets as heavy as 4,599 lbs. The overall length of the truck varies as there are three different size beds for this truck.
Read more: 1998 Chevrolet Silverado Specs | eHow.com http://www.ehow.com/list_7634078_199...#ixzz1Abg8iCMH
There is also the same info on other sites as top the weight of the truck.. You had me 2nd guessing myself. I was close
Quick Reply: Weight of a '98?
