1.6 roller rockers
Originally Posted by moparguy0504
Ok so what if i sent these back and got the harland sharp pedestal mount 1.7s. These would work right. Now i just need to know what size pushrod i need. I know i will need new valve covers or to make some modifications to the stock ones. But is there anything else i will need. to do these. Ohh yeah and should i get the adjustable or non adjustable ones the part numbers are CSP-S70037 for the non adjustable and CSP-S70037A. Thanks for all the help so far.
TJ
stud conversion
this is all you need,just order this kit from summit and go to work.You won't need different pushrods with the stock cam,and these are adjustable.So if you decide to get another cam you just get .050" longer pushrods.With non-adjustable you can run them with the stock cam with no prob.But if you change your ca you have to convert them to adjustable or order custom length pushrods(pain in the ***).So just keep the cranes and order the kit,if you need anymore help or info just ask
DEPUTY
DEPUTY
You won't need longer pushrods with the 1.7's and stock cam,you can get the HS 1.7 non-adjustable and convert them to adjustable later if you want.But summit says there is a two week wait so I would talk to HS direct.
DEPUTY
DEPUTY
KINGCYCLES
10-02-2015 10:21 AM
