Dodge Engine & Exhaust Performance All EFI, Hemi, Magnum, 4.7, 5.9
46RE Converter?
Old 11-19-2005 | 01:07 PM
1Red Dawg's Avatar
Default 46RE Converter?
I have the 46RE tranny and I have 4:10 gears in the rear, what would be a good RPM stall for street/strip application???
Old 11-19-2005 | 04:40 PM
MrDestinE's Avatar
I would maintain the lockup on the converter for the street... I am thinking if I remember correctly those already have 2200 stall built in... I would probably stay around 2800 or so with the stock cam.
TJ
Old 11-20-2005 | 04:12 PM
1Red Dawg's Avatar
I'm going to be getting a bigger cam also!
Old 11-23-2005 | 10:20 PM
MrDestinE's Avatar
Your cam and engine size will dictate your stall...
TJ
Old 11-24-2005 | 04:46 AM
ktmrider's Avatar
TJ
Yeah, I would not go too much above 2800 unless you are totally dedicated to the 1/4 mile.
Old 11-24-2005 | 02:27 PM
MrDestinE's Avatar
Just remember..... IF you go say a 2800 stall and it does not retain the lockup feature.... if your cruise speed is below the lockup point of the stall then you will tend to overheat the tranny fluid due to excessive slippage..
TJ
Old 01-13-2006 | 10:53 AM
Banned
Go with a 2600 stall for daily driving. Unless your cam is above .600 lift. The gears are already helping. You need to try to match the gears, cam, and converter. I recommend
1-866-309-8200. Ask for robert. Tell him you want the 2400-2600 stall or the 2600-2800. He has good prices and knows his stuff. This applies to the 5.2 and the 5.9.
Old 01-16-2006 | 11:13 PM
1Red Dawg's Avatar
Thanks for the info yal!
jscherbs
03-24-2017 07:20 PM
Go5.3tt06
25
09-04-2016 10:25 AM
TAPyvehc93
01-08-2016 10:47 AM
jtphelps289
09-11-2015 06:37 PM
06 4.8
09-11-2015 10:36 AM
Quick Reply: 46RE Converter?
