Alright, projects?
Alright, projects?
Can't let them chevy and ford guys out do us. what do you have and what do you have planned? this is what I have
Current Performance Mods
-K&N Gen II Cold Air Intake
-F&B 50mm Throttle Body
-Mopar Performance 4bbl M1 Intake
-180 Thermostat
-B&M Transmission Cooler
-GS Motorsports headers & complete exhaust, catless, with Fastman O2 sims
-MSD wires
-NAPA brass cap and rotor
-Lakewood Traction Bars
Upcoming Performance Mods
-Edelbrock Magnum heads, ported and polished, milled, ~10.3:1 compression by the Dan the Fastman
-Cammotion Cams custom grind cam 218/224 .525/.542 112° LS by Dan the Fastman
-Fastman 53mm Throttle body
-Comp Timing Chain
-Comp Gold 1.6 Roller Rockers
-Comp harden pushrods
-APS under drive pulleys
-MSD, Digital 6, and HVC coil
-Autolites 3923
-Martin Saine Transmission 700 hp/700 tq with Martin Saine torque converter
-B&G Flash
-NX Dodge 15lb Bottle EFI Single Nozzle System, Gen-X 3 accessory package, and digital maximizer.
-Permacool transmission fluid filter
-4.56 gears
-SSBC rear disc brake conversion w/ stainless steel rotors upgrade
-Line Lock
-Caltracs
-M&H Racemaster 275/50 R17 drag radials
-Bogart billet light drag rims and skinnies
-Hoosier drag slicks 29x11 15s
-QA1 RC 1914P front shocks, TC 1539P rear shocks
-Viper Fan
Current Eye Candy Mods
-APC Dodge Motorsports seatbelt cushions
-Drive a Dodge Naked sticker
-Harley-Davidson Sticker
-MAD R/T Sticker
-National Dakota R/T Club sticker
Upcoming Eye Candy Mod
-Pace Edwards roll top tonneau cover
Best Times
60ft 2.2, 9.8 in the 1/8, and 14.8 in the 1/4 mile
6/23/05 (light modification/current except flash) 259 RWHP @ 4950 RPM, 309 RWTQ @ 3950 RPM SAE corrected. Temp out 87F, 92% R.H. elevation 950 ft. engine temperature 180 EST.
-180 Thermostat
-MSD wires
-Comp Timing Chain
-Autolites 3923
-B&G Flash
-4.56 gears
-Line Lock
-Caltracs
-Viper Fan
-MAD R/T Sticker
Best Times
What we're supposed to work on our trucks?
Nothing too terribly big for me.
This weeks plans:
Swap to 4bbl manifold, (assuming new fancy lifters arrive)
Install new TC.. been waiting on a remote filter but i'm about to give up on that. Did I mention how much i'm NOT looking forward to this one, gonna need a 12 pack or two for that job.
And do some more work on the never ending project that is a standalone.
The rest of my plans/track times are top secret from here on out
This weeks plans:
Not much planned for my truck. Taking off the SRT-10 muffler (hopefully on 7/11), sounds like crap on a Hemi. Then get a Superchips tuner when it's released for the 04-05 Hemi Rams.
Jim
Jim
Tommorow, my traction bars, kn heatshield, and bed tie down hooks are going to the powder coaters.
Saving a lil more money and getting QA1 shocks all around to completment the TVS
Then the tranny is getting done, already have the 2400 stall custom converter and transgo shift kit, just need to pull and rebuild the beast.
After the trannies back in its gettign mopar headers, custom dual 2.5 into single 3.5 y pipe, 3.5 inch cat, 3.5inch hook aero chamber muffler.
Then prolly a TB and M1, .600 springs then 1.7 rockers.
Performance mods mostly..
KRC fuel rails
Adj Fuel Psi Reg.
New fuel lines -10 feed and -8 or -6 return
Finally install my A-1000 pump
Haltech Standalone and some dyno time.
KRC fuel rails
Adj Fuel Psi Reg.
Performance mods here too.
KRC is getting my truck Aug 8. Can't wait to see the numbers once they tune it on the dyno after the new parts go in. I'm like a kid waiting on Christmas...
FormulaZR
09-14-2015 05:23 PM
