hemi swap no start :(
well my buddy did a 05 hemi swap on his 03 4.7 he did the light harness and engine harness and an 05 cumpter everything was simple plug and play but now the key turns all electrical works but wont crank any idea? does it need a reflash on the pcm? any info would help him out thanks
bump tried what FrostKing said and thanks for the tip, well we took it to the dealer and they cant find anything on it and was told the pcm isnt getting signal tried a different pcm ans nothing any ideas?
If the starter has ground and 12v when you trigger the relay, either the starter wire isn't hooked up or your starter is toast. PCM won't be aware that its cranking but the engine will still turn over.
if thats the problem will the pcm not get signal? Im just shocked that the dealer said they dont know what to do lol they swapped 3 pcms and still no luck
i have not touched his truck only been around when his so called master tech did the swap and rigged the starter due to beening an 03 ram with 05 parts and was told something about the hemi starter not fitting due to extra coneters which i have no clue only know that they had to rigg it and now the tech and dealer dont know which starter to use lol
