10 sec pass today
#21
Congrats Dave! You hit the 10's before I did you son-of-a-gun. Once I get this trans rebuilt, I am commin' for ya!
btw... what did you have your heads torqued to? I torqued my studs to 90ftlbs with moly lube and haven't had a problem so far with 10# on MLS gaskets, 9.7:1 CR and 19* of timing. I am sure you will get everything sorted out soon though.
The heads were torqued to whatever the specs are. I can't remember them though. The heads have been milled twice to even them out. We suspect the decks were just to thin. I have a set of All Pros waitng to go on the engine. They would have been on the truck already, but the truck was running so good, I hated to mess with it. Can't wait to see how you do when you get the tranny in it.
#22
9 Second Club
why havent you posted the vid?
sd/hd=standard/high definition
http://mssftw.com/videos/SD-Quicksilverado-10-93.wmv
http://mssftw.com/videos/HD-quicksilverado-10-93.wmv
oh i see you posted sd link already...HD link is posted as well now for those with a fast pc
#23
#26
Great passes Quick! I sure do like your truck and your setup.
#28
Got the heads off thursday. The head took the worst abuse. It can be repaired though. The steel liner is fine. The aluminum block was torched a little. It can be fixed without pulling the engine though. The All Pro heads will go on next, Truck should be up and running by the end of the week.
