1000+ rwhp lq4 spark plug reccomendations
Performancetrucks.net wins the contest. I was having a discussion with a friend over the amount of bullcrap spewed over the techie boards so I did my own small experiment. I posted this same question on ls1tech, yellowbullet, and here. So far, your reply is the only one that actually answers my question, AND in my opinion answers it correctly.
Now with that out of the way. I have been running the 8s for some time now thru the cold dry winter. Now that the hot heavy summer air is setting in around here, I was thinking about trying the 7s. Your thoughts?
Pt88 cast wheel, 21-22lbs of boost
I run tr6s on e85 up to 18psi gapped to .28, but ill switch to br7efs if I go any higher. And yeah dont go to ls1tech for boost info unless you wana run a ls6 cam and a on3 turbo...
SlvrSierra4.8
10-01-2015 09:39 PM
FormulaZR
09-14-2015 05:23 PM
