11.72 @ 113.83 4wd Silvy Radix & 75Shot
LMAO...5 gallons of 110. Raced with half a tank of fuel.
I noticed it didn't shift were it was supposed to on the 1/2. I want a 6300 1/2 shift. And I am okay with the high 2/3, but that's as far as I want to go. I don't know if it had anything to do with the scanner was slow or not. I keep forgetting to send my log and tune here to work so I can verify my shift points.
IAT in meth...LOL I have 2 heat Xchgrs too. Stock one is turned sideways under neath the front with no air damn. I then have a small radiator style Xchgr in front of my radiator. I also recently went to E-fans. Hell there's .2 in the 1/4. LMAO![The Jester](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_jest.gif)
Rabbit Release...lmao
![Rotflmao](https://www.performancetrucks.net/forums/images/smilies2/rotflmao.gif)
You should have told me you ran that! Kick *** and congrats!!!!!!!!!!!
![Cheers!!](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_cheers.gif)
Nice break down, For comparison sakes I...: Launch at 1200-1500, I run about 21* advance throughout my run, 1/2 shift at 6K, 2/3 shift at 5950, TCC apply at 95 MPH, AFR 11.7 - 11.9 the entire run and my IAT's are COLDER (nothing over 120* for the entire run).
Congrats!!!
![Happy](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_stretch.gif)
Congrats!!!
Tight AFR's the whole way down the track Kevin. Pretty good tuning. You ever tried richer? I know you are running a mix though right? I run 100% meth.
2nd fastest 5.3 ECSB
+1 ![Devil](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_devil.gif)
If I understand you correctly mine does the same thing about the same place. Right after the 2/3 shift it bogs as the TC locks up? I tried to get you a scan last night.
I already congratulated you, 3 times. Don't get too comfortable Chumley
DIP in RPM
102MPH/5123RPM
17.5*
151* IAT
10.52 AFR (was 10.9 1 frame before)
and then it dipped to 4749RPm at 103MPH
Spark went up to 18* and AFR was 10.67.
TCC started "Apply" process.
102MPH/5123RPM
17.5*
151* IAT
![MAD](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_mad.gif)
