TIME SLIP DATABASE
11 sec 4.8 daily driver!
Old 10-16-2010, 10:20 AM
sprayedenali's Avatar
he went 13.50 on motor.
theyre really 28x11.50x16 ET Streets
and we think the #6 injector is really weak, so that cylinder is running lean, but there wasnt a whole lot we could do once we go to the track... but its definitely got more left in it!!!!
Old 10-16-2010, 10:34 AM
chevrolet all the way's Avatar
sorry guys i was excited and very sleepy lol. yes it ran 12.000 on nitrous and 13.5 on motor with the nitrous tune so im sure that could be faster too.
they are 28 inch tires
like mitch said there is plenty of power left in it as long as i can hook and really dial in the tune!
thanks for all the congrats too!
Old 10-16-2010, 10:37 AM
Originally Posted by RibeiroBJJ
Congrats That thing is moving for sure!!! Gives me hope for my setup!! What on/off rpm's did you have the window switch setup at?
-Are your Dr's 29" tall? It says 39x11.5 MT streets probably a typo...
it was cutting off at 6700 i believe and cutting on... i cant rememebr the rpm but it was getting out about 30 feet or so before it sprayed.
Old 10-16-2010, 10:48 AM
the 11.8 run the switch was set at 2500/6900
the 12.0000000000000 run was 2500/6700
the last run where it spun sooo bad was 2000/6900
Old 10-16-2010, 10:50 AM
foose04's Avatar
Very good my friend. Only thing that would have made it better is a video camera.
Old 10-16-2010, 11:00 AM
ive got a few videos that ill upload in a little bit. the 11.87 pass was mostly of our volvo... the guy we got to record it is a volvo guy, so he wasnt too concerned with the truck! haha
Old 10-16-2010, 12:02 PM
11 Second Truck Club
fastrt's Avatar
great times man! little motor is running strong! so yall are spraying at 2000rpm? damn thats low. did you mean 3000? I have mine set at 3200/7100 and spray thru the shifts.
Old 10-16-2010, 12:11 PM
nope, 2000
its set so low so it flashes the converter harder. by the time there is actually any substantial load on the motor its well above 3k, so its fine. basically from when it starts spraying thru the next 1000 RPM its loading up the converter and basically free revving, so not really any danger of a backfire or anything
Old 10-16-2010, 12:12 PM
Congrats on the great times. Do you have alot of port work to the heads or are they just cleaned up?
Old 10-16-2010, 02:50 PM
they are port polished, larger intake valve, media blasted combustion chamber, supposed to be a 5 angle valve job, and milled a good bit.
Quick Reply: 11 sec 4.8 daily driver!
