12.8 @105 07 nnbs xcab vmax.. pics
#21
at first when installed the converter the truck had only minor bolt ons and yeah it felt pretty loose butnow cam,headers etc it feel nice and tight yet brake stall 3200 on slicks.i think edge makes some bad *** converters
#22
i just noticed you run the hoosiers e/t's??? might want to try out the hoosier full drag slick, I bet it'll hook alot better and your 60's should come down... its hard to tell on your video if your truck is spinning or just the weight transfer movement??
#26
I have an 07 Ly6 6.0 and I am also installing an L76 car intake. What water pump did you end up using? I have a Camaro water pump that I was trying to use, but the pump hits the timing cover because there is not enough clearance behind it.
#29
Factory water pump /w factory 90mm DBW TB. We do some quick minor fabrication to make it fit. no biggie.
