4.10 gears didn't help my 60' WTF ( Did not spin)
#51
Resident Retard
Pre gears: ~50 degrees, ~-500DA
Post gears: ~65 degrees, ~+600DA
Code:
RPM 400 800 1200 1600 2000 2400 2800 3200 3600 4000 4400 4800 5200 5600 6000 6400 6800
g/cyl ---- ---- ---- 0.617 0.617 0.605 0.624 0.639 0.673 0.734 0.712 0.717 0.725 0.729 0.713 0.691 ----
Code:
g/cyl ---- ---- ---- 0.501 0.546 0.549 0.553 0.572 0.639 0.667 0.689 0.694 0.693 0.697 0.681 0.647 ----
Did you filter WOT only?
#52
Yeah that's WOT only. Only some low end timing changes and shift points. That 'post gear' run was the best MPH so far with the truck.
#54
1100DA difference between runs is night and day IMO...
A perfect example is the day before yesterday it was about 65* out and my truck reallllly likes the cool temp. From a dead stop I can roast them no problem into second. Today I tried the same thing and it spins a little then gets traction, but it's 82* out and more humid than AIDS
#55
Well, rule of thumb says .1 in the 1/4 for every 1000'. In my experiences air temp itself made more of a difference than overall calculated DA. Which would say that I think 15 degrees would be worth more than just a tenth.
#56
I think you should run it in some cooler weather and see how it goes. I ran my best full bolton time the week before they closed the track for winter. I went back in late spring to mess around with some friends and ran 3/10 slower. About 35* difference in temp.
Raggedz71
07-29-2016 10:20 AM
silverstreak07
06-28-2016 06:29 PM
