TIME SLIP DATABASE
4.10 gears didn't help my 60' WTF ( Did not spin)
Old 10-14-2009, 03:11 PM
  #51
Resident Retard
BlackGMC's Avatar
Originally Posted by JonCR96Z
Pre gears: ~50 degrees, ~-500DA
Code:
RPM	400	800	1200	1600	2000	2400	2800	3200	3600	4000	4400	4800	5200	5600	6000	6400	6800
g/cyl	----	---- 	----	0.617	0.617	0.605	0.624	0.639	0.673	0.734	0.712	0.717	0.725	0.729	0.713	0.691	----
Post gears: ~65 degrees, ~+600DA
Code:
g/cyl	---- 	 ----	 ----	0.501	0.546	0.549	0.553	0.572	0.639	0.667	0.689	0.694	0.693	0.697	0.681	0.647	----
Man that is really interesting way to compare things, i like that... So you did no other tuning inbetween? I dunno, definately seems like something happened inbetween those two logs...
Did you filter WOT only?
Old 10-14-2009, 03:22 PM
  #52
JonCR96Z's Avatar
Yeah that's WOT only. Only some low end timing changes and shift points. That 'post gear' run was the best MPH so far with the truck.
Old 10-14-2009, 03:29 PM
  #53
Resident Retard
BlackGMC's Avatar
How much do those tires and wheels weigh? I used to have some 20's that weighed 90+ each and when I switched to factory 16s, both were the same height tire, it felt like I added 20hp..
Old 10-14-2009, 03:40 PM
  #54
jakebdb56's Avatar
1100DA difference between runs is night and day IMO...
A perfect example is the day before yesterday it was about 65* out and my truck reallllly likes the cool temp. From a dead stop I can roast them no problem into second. Today I tried the same thing and it spins a little then gets traction, but it's 82* out and more humid than AIDS
Old 10-14-2009, 03:49 PM
  #55
JonCR96Z's Avatar
I'm sure that they are close to 90lbs. As I said with my truck adding 30lbs per wheel was worth .1 in the 60' and .4 and 3mph in the 1/8, and they were about a half inch difference in height. The wheels and tires that IH8FORD is putting on his for next weekend should be around 50lbs and 5 inches shorter.
Well, rule of thumb says .1 in the 1/4 for every 1000'. In my experiences air temp itself made more of a difference than overall calculated DA. Which would say that I think 15 degrees would be worth more than just a tenth.
Old 10-15-2009, 10:49 AM
  #56
jakebdb56's Avatar
I think you should run it in some cooler weather and see how it goes. I ran my best full bolton time the week before they closed the track for winter. I went back in late spring to mess around with some friends and ran 3/10 slower. About 35* difference in temp.
Old 10-15-2009, 01:55 PM
  #57
12 Second Club
fastlt1's Avatar
Sorry I still think your convertor is to tight and you need a higher stall.
Oobray
06-13-2022 03:38 AM
Raggedz71
07-29-2016 10:20 AM
silverstreak07
06-28-2016 06:29 PM
So.cal Wrk Sled
07-26-2015 12:10 AM
Cowboy Tom
07-21-2015 10:29 PM
Quick Reply: 4.10 gears didn't help my 60' WTF ( Did not spin)
