TIME SLIP DATABASE
6.517@102.73
Old 05-24-2012, 11:46 PM
I have a gauge for that
Atomic's Avatar
Default 6.517@102.73
Had to try out my new intercooler and turbo so I went to the track...it was warmer today than it has been, in the mid 90s so I had to wait until the sun went down before I got my best run:
60ft - 1.467
594ft - 6.079
1/8et - 6.517
1/8mph - 102.73
My goal for the night was to try for a 6.33 since that equates to a high 9 in the 1/4, but it wasnt meant to be. I measured my 0-60 on my log as 2.43 seconds, which I dont think is too shabby...It looks like upgrading the intercooler, some more timing, and a bigger compressor wheel (76 vs 80) gave me 0.3 1/8et and about 3mph.
The intercooler did well. I took off the front grille so it could get some better airflow and when I launched at 12psi IATs were 97 and at the end of the run when the boost hit 20psi IATs were 133. I had meth spraying the whole time, but not enough actually. I havent had the chance to test pressure drop across the intercooler but I suspect its much better. Boost was 17ish most of the run with it going to 20psi at the 2-3 shift. Timing was 14-15ish most of the run, until it shifted to 3rd and saw some knock so it pulled it down to about 7degrees. This probably cost me 1mph or so on the big end.
Most importantly, my injectors are maxed out. The tank is about 25% e85, and my IDC was 100% at 5600rpm and 16psi, hitting a max of 113% at 6100rpm and 18psi. I was spraying meth, but not enough apparently because it was 4-5% lean most of run (0.80 lambda, 0.76 lambda desired), which explains the knock when it shifted to 3rd and boost hit 20psi. I am pretty sure its the injectors and not the pumps (80lb at 3bar injectors, 96lb@4bar, and dual denso 1020 pumps). Either way, the system is maxed at about 15psi with the 80mm wheel. If I were to run 100% gasoline and spray more meth it would probably be alright for 18psi ish.
I have the knock sensors at the stock settings and dont plan on touching them. I drove the truck 30 minutes home without any issues and everything is fine. I did scare myself pretty good though since my first run I had my boost controller set incorrectly and saw 20psi most of the run with no meth, and a really lean VE table for that area making it about 20% lean, but timing was pulled aggressively and all was well.
This is on a basically 100% stock suspension expect for 2" drop shackles in the rear. I got my new shock brackets today in the mail to redo the rear shocks, and stuff to strap the front end down should be here sometime. I did manage to spin all 4 drag radials at the start though, but it didnt seem to hurt my times.
I did take out my tools and my tailgate which together are about 115lbs, so the truck should weigh right around 5000 with me in it. So based on the speed im putting between 800-850 to the ground, which was my goal for the truck in the first place. I had a lot of people come up to me at the track that were really impressed and that was flattering of course. I feel with this combo with slightly bigger injectors (120s perhaps) and a better intake I could hit 9s pretty easily, but thats more than I want to do right now, its just working too well to start making major changes. Now I just need to get that ladder rack on...
I only have a video from my gopro as no one else wanted to come out tonight (im looking at you, Blake and Mitch...)
white turbo silverado at holiday raceway - YouTube
Heres a vid from earlier in the day with a 9psi shakedown run
http://youtu.be/jisCwy8JsQM
Old 05-25-2012, 12:01 AM
foose04's Avatar
Awesome job man!! Truck sounded damn good.
Old 05-25-2012, 12:11 AM
9 Second Truck Club
stock48's Avatar
Getting there man! Are those pumps hot wired? How much meth are you shooting?
Old 05-25-2012, 12:23 AM
11 Second Hall Moniter
AKlowriderZ71's Avatar
Nice!!
Old 05-25-2012, 12:32 AM
Mud slinger's Avatar
That's awesome! Must be nice to just roll up to the tree, not do a burnout, and still hook.
Old 05-25-2012, 06:16 AM
Wide Open's Avatar
Nice run. I love the way the 80's shift. Not nearly the drop off as the 60's have between gears.
Old 05-25-2012, 07:03 AM
Atomic's Avatar
Thanks guys. I have the second pump on a hobbs switch set to 3psi. Both are wired with 10ga wire directly from the battery. I have a M10 and M15 meth nozzle and have it coming on about 4psi, I had my controller set to 4 but probably should have cranked it up some more.
I did a small burnout to clean the tires off but not hardly any smoke.
Old 05-25-2012, 08:26 AM
sprayedenali's Avatar
i wish i would have made it..... id bet we could have had another pretty good race!! we will make it back out soon!
and damn nice run!!! thats moving on out!
Old 05-25-2012, 09:53 AM
JoeyGC5's Avatar
Awesome results Richard. It's always good to see that the small changes are actually paying off.
So does this mean that Mitch has to turn the wick up now to stay even?
Old 05-25-2012, 09:54 AM
ak2007r6's Avatar
Thats badass man!
Quick Reply: 6.517@102.73
