Anyone scale there RCSB GM
I was looking for some similar info recently and came across the specs for a stock 2006 rcsb Sierra. Curb weight = 3956, Ft wt = 2319, Rr wt = 1637 for a 58.6/41.4 split or 1.415:1 front to back ratio.
I would also be interested in seeing some real world 4 corner scale results.
Hunt&Fisherator
I know skeet has had his truck scaled but the weight distribution will be different due to his 4 link and cell location.
I plan on having mine scaled once it's getting closer to being on the track. It will be on leafs will a factory tank so it'll be closer to most everyone else.
Location: Where our street cars are faster than your racecars..Mississippi
Hunt&Fisherator
How do you figure that? The 4 link will greatly reduce the weight in the rear of the truck.... Go pick up a leaf spring and then go pick up some DOM tubing and get back to me....
Not only that, a fuel cell located between the framerails behind the axle will affect a 4 corner bias greatly since these trucks come with a large plastic tank on one side outside the frame.... I figured what I posted would be easy enough to wrap your head around..... Guess not....
Yes, the actual weight will be reduced, I was thinking of the actual effects of the 4 link.
I never mentioned anything about your cell/tank comment, I figured you could read..... guess not...C U next Tuesday.
peace
Hog
