this is bad!!!!!
i think 16 to 18 psi won't hurt you. 13 seemsreally low, i ran 12 psi in my dads car and it swayed like **** on top end, and it only ran 12.76 @ 106.
damn it launches good though. i agree it could take some more air...i also think those tires are alot lower than 13 psi. i would serously check them with a different guage and see where they are at. my last time out i set my 28x10's as low as 10 psi trying to get it to hook and they never did that...ofcorse i never got them to hook like that (zero track prep). never seen these tires flaten out like that though.
9 Second Truck Club
Nice run! You could stand a bit more air try upping the psi 2lbs at a time until you break traction, then let it back down. There is a fine line there. I run 4 of those same tires, just painted the ET black. That type of tire tends to wrinkle alot even at 18~20 PSI. I run 18psi rear, and 22-24 front(4x4).
This is the only picture I have of my tires.
![](http://img520.imageshack.us/img520/7154/stock48pd1.gif)
lukn4trbl355
10-21-2015 11:19 PM
