bad ass cobra jet build
bad *** cobra jet build
Why GM can do this to the camaro
http://www.stangtv.com/forum/followi...html#post10851
Following the Complete Build of a 2010 Cobra Jet
Following in the rich tradition of previous Ford factory built Mustang race cars like the 1968 Cobra Jet, the Boss 429 and the FR500S Mustang Challenge car, Ford Racing and AAI (aka the Mustang Plant) started work on a production run of 50 Cobra Jet Mustangs. Two years ago, Ford Racing built 50 Cobra Jet Mustangs at Ford vendor facilities, but the 2010 edition of the car returned home to Flat Rock, Michigan.
For a complete 2010 Cobra Jet build picture gallery, CLICK HERE.
ALSO CHECK BACK IN A FEW WEEKS FOR THE FULL BUILD VIDEO!
In 2005, AAI started building the S197 version of the Mustang and to date has produced over 800,000 units, a number thats pretty impressive considering its a two door sports car. All V6, GT and GT500 models are manufactured on the main line and the build team knew they wanted to be a part of the historic car. While impossible to build on the high volume main line, the 2010 Cobra Jet was built on the AAI pilot assembly line where the plant performs new model training and workstation development. The pilot assembly team is made up of seasoned main line technicians and welcomed the challenge of building such a high profile Mustang.
A 2010 Cobra Jet starts out life as a “prepped” body-in-white 2010 Mustang. Prior to arriving at the Cobra Jet line, a 2010 shell was produced on the main AAI body line and painted Performance White. After paint the unit is sent to Watson Engineering in Taylor, Michigan for an NHRA legal 8.50 e.t. 10-point chromoly cage install. Watson Engineering also installed the rear back seat delete panel, firewall cover plates and transmission access panels. After the cage and body updates were complete at Watson, the body was shipped back to AAI for another trip down the main assembly paint line to coat the cage and interior Performance White in preparation for the Cobra Jet line.
There are two Cobra Jet assembly lines that merge into one assembly line after the car is built into a “roller”. When the Cobra Jet body hits the first build station, the line technician removes the doors for easier access to the interior. The composite cowl hood is also removed to access the engine bay. All installed parts are binned near the station where they will be installed. A computer terminal also provides the technician with build information specific to each car.
Station 1 of the Build
The first part installed on the car is the main wiring harness for the electronics. An electrical bulkhead panel is installed on the passenger side firewall and the battery cable is routed towards the trunk for the electrical kill switch that is mounted on the rear of the quarter panel per NHRA specifications. One cool thing about the Cobra Jet build is that the only parts installed are go fast or safety related items. The body is void of insulation and other sound deading material that weigh a car down. Ford Racing engineers also kept wiring to a minimum to save weight.
05GMC4.8
08-07-2015 09:55 PM
