Can I run a 16x10 rear without issues?
11 Second Truck Club
Those look just like the ones I run. I posted a pic in your other thread. Mine stick out past the fender a little. No problem for me as I only use them at the track anyways.
Regardless of the backspace they will stick out because like BigKID said you can't make them tuck because of the bolt on the brake caliper. I put the truck on a lift yesterday to look for myself and sure enough the stock 16" wheel is like 1/2" from hitting the bolt on the inside. If it wasn't for that bolt you could tuck the wheel in more.
If you go to a 17" wheel then you can go 10" wide and still tuck inside the fender.
The A-1 CARDONE part #'s are:
18-4713
18-4712
from an '02 s-10 blazer 4.3
GMCtrk
07-17-2015 06:39 PM
