TIME SLIP DATABASE
cant figure this truck out . HELP
Old 07-13-2008, 01:25 AM
charcold-bowtie's Avatar
do realize, it is built into every good tune, that when the IAT get up around 100 degrees, the tune begins to pull timing. At 100 it is around 3 degree then ramps up from there. A heatsoaked truck can pull timing pretty easily. Especially with a MAF that has a slow reading IAT sensor. Ive never even had a 60 foot better than 2.2 booo. thats with 4.10 and stall. But im in texas. Turbo 60 foot times will come later.
Old 07-13-2008, 02:44 AM
11 Second Truck Club
Cuerva's Avatar
1.94 is still high for 85 deg weather. I used to get 1.80-1.81 in 90+ deg weather on my 5.3 on 28's.. I think you need to try a 3400 9.5" PI Converter, preferrably a multidisk since you have nitrous.
Old 07-13-2008, 03:06 AM
adrenalinep's Avatar
I would try 26" drag radials or et streets or go to some 4:10s. Either one would drop it some imo with your current set-up . The 4:10 and 3800 stall would drop it for sure .
Old 07-13-2008, 12:31 PM
ZO6Ted's Avatar
That cam probably doesn't make enough power down low. I think a higher stall and gears or shorter tires would help alot. Can you run more timing?
Old 07-13-2008, 01:23 PM
ap2002's Avatar
Originally Posted by RickLowpez
so at 80 ur at 2400 or so?
i believe so, i could go for a ride and verify but truck is broke down..
dont get too desperate rick, wait for good weather before you change anything, except like going to 4.10's, thats always a good mod for some better e/t.s
Old 07-14-2008, 01:25 AM
9 Second Truck Club
stock48's Avatar
well 85 deg.weather,08 rcsb gmc 91oct tune. full bolt on 220 high lift cam , 3500( break stall 3200) edge converter,373s, 28 m/t and only a 1.94 60ft. but went 13.35 at 103.6 mph. all night 103 mph so i was happy on that but not the 60ft. i tried different rpms also but nothing worked . so do i need 410 gears? bigger stall? what could it be? need suggestions asap
Famoso is a shitty track, the DA there is high for the physical elevation, and all the **** in the air kills power. Make a trip up to Sac you will run faster. We pick up at least .2-.25 tenths on a 10 sec car up there, you could gain even more than that.
Old 07-14-2008, 06:58 AM
zippy's Avatar
You need to get a log of this happening. I'd bet you're having an issue with either power enrichment not coming in soon enough or a torque management issue. Could be the power hop setting, stall speed setting, etc, etc. With so many torque management settings in these newer trucks any one of those missed could cause that problem. I doubt a lack of torque from the cam would cause a problem with a 3000+ stall converter. Even in that weather I'd have expected to see around a 1.88 or so. I'd guess 1.7's in good weather with that truck.
Old 07-14-2008, 12:05 PM
RickLowpez's Avatar
yup im gonna have 2 wait till good weather
wrb002
08-31-2015 12:00 PM
black6spdz
07-16-2015 01:32 AM
4B11T
07-13-2015 03:48 PM
Nimoryan
07-05-2015 03:50 PM
Quick Reply: cant figure this truck out . HELP
