TIME SLIP DATABASE
This combo good enough for 11's?
Old 01-08-2012 | 07:06 PM
lglowe's Avatar
Default This combo good enough for 11's?
Well I have a 2002 extended cab short box silverado and am really hoping to bust into high 11s. Just want to know how hard it will be with my combo. Mods
6.0 , isky 212 cam.
Kb turbo kit with magnum t76 .96 ar 3.5 down pipe.
No meth yet on 93 octane. Gonna run 10-11# spring.
4l80e/ stock converter, 4.10s for now but will be swapping to 3.73 or 3.42 before to long.
I have a nitrous plate kit on it for use out of the hole with about a 75 shot till about 6-7 psi if needed.
I have caltracs and hoosier 28in slicks also. What yall think?
Old 01-08-2012 | 07:11 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
If you can get traction, and the tune is perfect, you can get there I think.
Old 01-08-2012 | 07:13 PM
custm2500's Avatar
Ph.D. in HUBRIS
You need a converter bad!!! Nitrous will help but you will have shitty 60 ft. times and that doesn't make a good foundation for a strong 1/4.
Without you have a chance, with you should be there with out a problem.
Old 01-08-2012 | 07:23 PM
lglowe's Avatar
Cool. I usually have good Da too. Elevation is only about 300 ft but on some cold nights iv looked and its been negative Da before.
Old 01-08-2012 | 08:51 PM
pittman's Avatar
Man, you have everything else..get a converter and you are there
Old 01-08-2012 | 09:22 PM
Beatdown Z's Avatar
Laid Back
Spray a 150 out of the hole and cut it off earlier to make up for that stock converter.
Old 01-08-2012 | 09:23 PM
10 Second Truck Club
Very possible sir
Old 01-09-2012 | 07:36 AM
slowec's Avatar
You are there unless you are really heavy. these trucks vary so much...
Old 01-09-2012 | 08:41 AM
Lil brother PI's Avatar
i dont see why not and mauybe a 100 shot to make up for the lack of converter
Old 01-09-2012 | 12:34 PM
TIM Z's Avatar
11 sec. Truck Mod
I bet with practice launching you will get what you are asking for.
I like 12 psi myself, feels so much stronger than 10psi.
Brake stalling works best for me.
