TIME SLIP DATABASE
This combo good enough for 11's?
Old 01-14-2012 | 11:49 AM
  #21
sprayedenali's Avatar
put a 100 shot on it, spray dead out of the hole and dont let up!
Old 01-14-2012 | 05:01 PM
  #22
Jake99's Avatar
Im pretty sure you have the better converter, the 6.0 can flash them close to 2500 rpm, can you get any spool brake stalling? I have the same turbo and cam as you do just in a 4.8 and this cam makes power everywere if there is boost, with a hit of n20 off the line your there, but you may have to shut it off when it spools up cause I see tire shredding going on when that boost comes in.
Old 01-14-2012 | 06:18 PM
  #23
lglowe's Avatar
Ha ill get back to you on the brake spooling this weekend. Installing everything now. How quick does that turbo spool on your truck? And I wonder how it'll spool on mine?
Old 01-14-2012 | 11:22 PM
  #24
Jake99's Avatar
I have 3700 stall so it comes in real quick whenever I get in it, I can brake boost 4 psi and it sends the tires to high heaven. cruising down the highway with my 4.56 gears at 2600 rpm if I roll into the throddle I can get into almost full boost, I was vary happy with the way mine spools, mines a p trim bb.
SLOPONY
20
10-18-2016 07:05 AM
kyle's v
10-04-2015 01:37 PM
DrX
08-19-2015 05:45 PM
Hmguyton
08-09-2015 06:38 PM
