This combo good enough for 11's?
#22
Im pretty sure you have the better converter, the 6.0 can flash them close to 2500 rpm, can you get any spool brake stalling? I have the same turbo and cam as you do just in a 4.8 and this cam makes power everywere if there is boost, with a hit of n20 off the line your there, but you may have to shut it off when it spools up cause I see tire shredding going on when that boost comes in.
#24
I have 3700 stall so it comes in real quick whenever I get in it, I can brake boost 4 psi and it sends the tires to high heaven. cruising down the highway with my 4.56 gears at 2600 rpm if I roll into the throddle I can get into almost full boost, I was vary happy with the way mine spools, mines a p trim bb.
SLOPONY
20
10-18-2016 07:05 AM
iregret
09-10-2015 10:00 PM
