Congrads Stock48, 10.65@126.99
#61
9 Second Truck Club
that really is a killer time. you must be doing something different than i was.
i ran a 10.91@122 at 13psi and a little nitrous. t76 nearly maxed out, 6.0 with a cam. turbo kit was pretty much identical to what you have. engine and tranny was about the same, converter the same. my 60 was more like a 1.68. track at 1500ft and a 50 deg night.
congrats. your doing something right!!
#63
9 Second Truck Club
I really wanted to uncap the exhaust, but It was hot, and I didn't feel like getting burned. I was also afraid it might lean me out. I need to go out one of these night's and try it out. Im going to add one more meth nozzle, so it should be ok. I have a 375 I want to add.
#64
How do I change this text
#66
single digit dreamer
i totaly maxed out a turbonetics t76 and couldn't run in the 10's. had to add a little nitrous to get it done. i also had a tail wind. cold night, 1500' elevation, open down pipe. like i said, he is doing something right
whats the specs on that turbo? is there drastic weight reduction on the truck or just the normal stuff?
#67
High on diesel fumes
#68
9 Second Truck Club
Truck was full weight, only thing removed was the spare, and tail gate. I still have the A/C, stock bumper, hitch etc. I was also running with over 3/4 of a tank of fuel in the stock tank. Had my tools, craptop, and some other **** in the truck too. I fucked something up in the fuel bucket so If I launch with less than 2/3 of a tank it falls on it's face. Truck was around 4900LBS before the turbo, 80E, and big drive lines. Has to be at least 5000~5100 LBS. One thing I did have was I rigged up a redneck ram Air that might have healped a bit. My truck makes the most Boost in 3rd gear, and i wasn't watching the boost gauge, I had my eye on the 12.2 AFR. Da was around 7000' when I ran. Temp was about 50 deg, with a cross wind. Barometric psi was 24.4 HG.
#69
9 Second Truck Club
Turbo is a water cooled Ball bearing turbonetics T76, .96AR, p wheel. It is not the normal T series, it is the next one up, but not the GTK. It was making 16PSI up hear @7000' elevation, until I ported the heads. After the heads boost droped to ~13PSI. Down in Pueblo @ 5000' It tried to hit 18psi, and I had to turn it down.
#70
FormerVendor
hmm, I have the GTK s trim.
I wonder how much boost i could run @ - DA on my 370
