TIME SLIP DATABASE
converter O.D. vs 60'
Old 10-01-2008, 04:25 PM
sickREDsierra's Avatar
Default converter O.D. vs 60'
well, one of the only things i went cheap on was my TC.. it was built in a factory shell (11") i think...
it stalls fine, but i think it is heavier than i need, and i am leaning towards a 9.5" verter of about the same stall speed.
just curious who has moved from a 10.5" or 11" down to a 9.5" of similar stall speed, and how your 60' dropped.
to this day, i have never had a 60' below 2.0 seconds
i think my engine would rev quicker with the smaller verter, and probably 60' a lot better.. i have seen 5.3's n/a on here around 1.7 - 1.8 .. damnit.
whats your thoughts?
Old 10-01-2008, 07:10 PM
ap2002's Avatar
r u running slicks? if not, then good luck getting it under the 2.0....
Old 10-01-2008, 08:58 PM
regency's Avatar
i had to put my stock verter (12") back in this week while the 10" 3800 is getting a new clutch and i can tell you it feels like its binding up tryin to rotate this heavy sucker at idle.
Old 10-01-2008, 09:14 PM
99Silverado5.3's Avatar
+1 on the slicks.
A 9.5" is less rotational weight..not only help you outta the hole but up top as well due to the motor reving quicker like you mentioned.
Old 10-02-2008, 07:53 AM
zippy's Avatar
I managed to get into the 1.9's with my truck with the 20's in full street trim with my 5.3L and only a few bolts on's with a TB converter. The best I did on the stock converter was 2.12, but I didn't have it in there long enough to try to get it into the 2.0's or better.
Old 10-02-2008, 08:52 AM
circusboy's Avatar
I'll let you know this weekend
Old 10-02-2008, 08:55 AM
TXsilverado's Avatar
im in the 1.8's on street tires
Old 10-02-2008, 10:31 AM
zippy's Avatar
I'm pretty positive I can get there on my 20's. With Cal-Trac's and QA1's (down the road) I want to try for 1.7's on my Hankook 20's.
Old 10-02-2008, 11:18 AM
what size/brand of street tire?
mine blow up off the line
Old 10-02-2008, 11:30 AM
BigKID's Avatar
There are other factors besides the actual diameter of the converter that play into how it launches your vehicle. Connverter weight as well as the converter's STR play a large role as well. The stock converters are very heavy compaired to aftermarket equivalents of the same diameter which use a billet case. Throw in small diameter which decreases case and internal componet weight, you get significantly less rotating weight at the crank. Most quality aftermarket converters have a much higher STR that a stock (or reworked stock) converter as well. According to you sig, your truck looks to be set up pretty well. You shouldn't have skimped on the converter. Get a good 9.5" or 10.5" aftermarket converter and I bet you will see some sub 2.0 60fts. Just FYI, I had a Yank TT3000 when I had about the same mods as you on a 5.3L (h/c/n2o/full bolton) and it did pretty well. I switched from it to a Fuddle HPTruck (9.5") and the truck came out of the hole much harder. I am currently running a Fuddle 9.5" in my 4L80 and pulled a 1.77 60' at Irvington a few weeks ago babying it out of the hole on 305/45/18 Nittos.
Quick Reply: converter O.D. vs 60'
