converter O.D. vs 60'
There are other factors besides the actual diameter of the converter that play into how it launches your vehicle. Connverter weight as well as the converter's STR play a large role as well. The stock converters are very heavy compaired to aftermarket equivalents of the same diameter which use a billet case. Throw in small diameter which decreases case and internal componet weight, you get significantly less rotating weight at the crank. Most quality aftermarket converters have a much higher STR that a stock (or reworked stock) converter as well. According to you sig, your truck looks to be set up pretty well. You shouldn't have skimped on the converter. Get a good 9.5" or 10.5" aftermarket converter and I bet you will see some sub 2.0 60fts. Just FYI, I had a Yank TT3000 when I had about the same mods as you on a 5.3L (h/c/n2o/full bolton) and it did pretty well. I switched from it to a Fuddle HPTruck (9.5") and the truck came out of the hole much harder. I am currently running a Fuddle 9.5" in my 4L80 and pulled a 1.77 60' at Irvington a few weeks ago babying it out of the hole on 305/45/18 Nittos.
i didnt plan on going this far when i put the verter in, that was my 1st mod actually. i just wanted to get off the line a little better...
i really need to buy a better and smaller one soon.
Wow, that really suprises me. I even pulled a 2.0 60' with a friends VHO when it was almost stock with a 245/70R17 General Ameritrac (spare winter tires) on it (spinning a bit also). There's a guy with a Silverado SS that pulled a 2.03 60' with only a CAI, cat back exhaust, and programming. That's a 5400lb truck on heavy *** 20's.
TX, those are a great street tire. The quickest 60' on a 20" wheel (2wd) is one of my goals.
Banned
1 Post
no one can explain any better
jscherbs
03-24-2017 07:20 PM
jtphelps289
09-11-2015 06:37 PM
