TIME SLIP DATABASE
converter O.D. vs 60'
Old 10-02-2008, 11:51 AM
sickREDsierra's Avatar
Originally Posted by BigKID
There are other factors besides the actual diameter of the converter that play into how it launches your vehicle. Connverter weight as well as the converter's STR play a large role as well. The stock converters are very heavy compaired to aftermarket equivalents of the same diameter which use a billet case. Throw in small diameter which decreases case and internal componet weight, you get significantly less rotating weight at the crank. Most quality aftermarket converters have a much higher STR that a stock (or reworked stock) converter as well. According to you sig, your truck looks to be set up pretty well. You shouldn't have skimped on the converter. Get a good 9.5" or 10.5" aftermarket converter and I bet you will see some sub 2.0 60fts. Just FYI, I had a Yank TT3000 when I had about the same mods as you on a 5.3L (h/c/n2o/full bolton) and it did pretty well. I switched from it to a Fuddle HPTruck (9.5") and the truck came out of the hole much harder. I am currently running a Fuddle 9.5" in my 4L80 and pulled a 1.77 60' at Irvington a few weeks ago babying it out of the hole on 305/45/18 Nittos.
well, you ***! why didnt you call me up, i live near irvington and run there all the time.
i didnt plan on going this far when i put the verter in, that was my 1st mod actually. i just wanted to get off the line a little better...
i really need to buy a better and smaller one soon.
Old 10-02-2008, 12:48 PM
99Silverado5.3's Avatar
Originally Posted by circusboy
I'll let you know this weekend
This is going to be a good comparison. Yank 3000TT to SS3600.
Post up your results!
Old 10-02-2008, 02:41 PM
TXsilverado's Avatar
Originally Posted by sickREDsierra
what size/brand of street tire?
mine blow up off the line
305/45-18 nitto 555r
ive only tried launching them on the track twice just to see what they had. im sure i could do better but they are meant for the street! the slicks are the ones to cook off at the track haha.
Old 10-02-2008, 03:34 PM
KevinF56's Avatar
i'll be going from the TT3000 to the SS3600 soon enough.
for the record, i have never gotten a sub 2.0 60', even with the TT3000... and that's launching in 4wd.
Old 10-02-2008, 03:44 PM
zippy's Avatar
Wow, that really suprises me. I even pulled a 2.0 60' with a friends VHO when it was almost stock with a 245/70R17 General Ameritrac (spare winter tires) on it (spinning a bit also). There's a guy with a Silverado SS that pulled a 2.03 60' with only a CAI, cat back exhaust, and programming. That's a 5400lb truck on heavy *** 20's.
TX, those are a great street tire. The quickest 60' on a 20" wheel (2wd) is one of my goals.
Old 10-02-2008, 03:58 PM
LowBlack99's Avatar
I've managed a few 1.9 but mostly 2.0-2.1 with a stock converter and 20's spraying just off the line.
Old 10-02-2008, 04:15 PM
alright! i just picked up a 3200 fuddle 9.5" verter from a member here.
probably send it in to the manifacturer for a clening/higher flash to 3400 or so, then test it out.
i am thinking this should be just what i need to blow my transmission up!
Old 10-02-2008, 05:20 PM
Banned
litreddevil's Avatar
no one can explain any better
jscherbs
03-24-2017 07:20 PM
Go5.3tt06
25
09-04-2016 10:25 AM
TAPyvehc93
01-08-2016 10:47 AM
jtphelps289
09-11-2015 06:37 PM
06 4.8
09-11-2015 10:36 AM
Quick Reply: converter O.D. vs 60'
