Couple clips from Sundays 8th.
I currently have stock 862's. Would it be worth the swap, maybe. We'll see how things go, but they may end up on this year if I want to start pushing closer to 25psi.
Their info:
Combustion Chamber Volume: 61.15cc
Compression Ratio: 9.5:1
Intake Port Volume: 200cc
Exhaust Port Volume: 70cc
Intake Valve Diameter: 1.89 inches
Exhaust Valve Diameter: 1.55 inches
Stock Head Flow Numbers
Chamber 61.15 cc----0.100--0.200--0.300-- 0.400--0.500---0.550---0.600
Intake 200 cc----------63 ---128----179-----210----218----221-----226
Exhaust 70 cc----------54 -- 93 ----121----145-----163----168----174
My 317's are cleaned up to 69cc.
Combustion Chamber Volume: 71.06cc
Compression Ratio: 10:1 LQ9 Flat top pistons
Compression Ratio: 9.6:1 LQ4 Dish piston
Intake Port Volume: 210cc
Exhaust Port Volume: 75cc
Intake Valve Diameter: 2.00 inches
Chamber 71.06cc----0.100---0.200--0.300--0.400--0.500--0.550--0.600
Intake 210cc-----------66-----142-----196---228----236---238-----240
Exhaust 75cc----------59-----104-----137---155----167---173-----177
Their info:
Nice race with the stang! you think going with such bigger chambers would be an advantage? If I ever get mine pushed as hard as yours I had planned on a milled ls6 head, that way I get a little bigger runner, bigger intake valve and match the stock 9.5 cr. Might work out good when you spraying n20 throw it tho.
Yeah but with some timing room of E85 and larger chamber to welcome airflow volume, plus the valves/ports, I think it would be ok.
My hold up is I can bottle feed it or boost it to where I think the internals will give before the added head HP is even really needed.
