Cranking problems
Our nova has a 13.5 compression bigblock, we have a jegs high torque mini starter, suppose to crank up 18.1, problem we are having, is the starter is barley spinning the motor over. We have timed it a TDC, but to no avail, the motor will run advanced, just wont turn over. When retarted, it spins better, but wont run of course. Battery has a 1100 ca, cables are clean and tight, any ideas?
yes sir, plenty of ground straps, the starter is lining up fine, from what i can tell by eyeballing it, no unneccesary wear, or patterns. cables are getting hot because its turning over slow, its like im using a stock starter, but im not lol.
well im thinking i might be off on the key way on the timing gear. had it running, timing light said 55*advanced, something is off, lol, tearing it down in a few, thanks guys
2002_Z28_Six_Speed
10-04-2015 01:34 PM
