TIME SLIP DATABASE
darg rim bead lock screw question
Old 08-12-2009, 04:30 PM
Dark Halo's Avatar
Default darg rim bead lock screw question
For you guys running screws on your rear rims to keep the tire from slipping are you using screws on both sides or just the front?
Old 08-12-2009, 09:20 PM
AustinDesigns's Avatar
Do both sides.
Old 08-12-2009, 09:56 PM
skeet's Avatar
just the outside !!!
even rich bogart told me when they do my beed locks that they can only do the outside of the tire, i asked what affects would it be not having the inside done, he said NONE!!! outside was sufficient
Old 08-12-2009, 10:30 PM
8 Second Club
Flaco's Avatar
beadlock is very diff than a screw on the rim..
Old 08-12-2009, 10:33 PM
Agreed.
Old 08-12-2009, 10:35 PM
Dark Halo's Avatar
cool, you are having a actual bead lock put in huh skeet? doesn't the bead lock clamp the tire to the rim? I didn't know if the screws would work any different vs the bead lock. Also skeet did you remove the tire from your rim prior to putting the screws in or leave it on?
Old 08-13-2009, 06:50 PM
turbosilvi's Avatar
i know bead locks are done on the out only, not sure about the difference with screws. i would do just the outside and see how that works unless someone knows for sure
Old 08-13-2009, 09:44 PM
skeet's Avatar
all i done was bring slick to 35 lbs ( below max pressure to set bead ) then got some screws from the hardware store and drill the rim and then set the screws.
left tire on rim!!
Old 08-13-2009, 09:45 PM
skeet's Avatar
thanks for the correction!! no wonder there so DAMN high lol!!!
Old 08-13-2009, 10:53 PM
That's why I posted "both sides". A bead lock puts the contact area that is holding the tire, completely around the WHOLE outside of the rim. A screw will only be holding where the screw itself is. Which is why it is better to do both sides of the wheel when using screws. Most times people only use 8 screws per side. That's 16 screws. 16 screws is still 85% shy of the holding capacity of ONE bead lock. Hence the reason you only need one beadlock.
Quick Reply: darg rim bead lock screw question
