TIME SLIP DATABASE
Diagnose my Timeslip, Help Needed Inside
Old 02-22-2009, 10:06 PM
SlvrSierra4.8's Avatar
Default Diagnose my Timeslip..... Help Needed Inside
Took the truck to HRP tonight w/ hopes of hitting a 14.xx at 90+ mph after the camswap. Ran a new personal best, but only reached half of my goal....... (timeslip below). Also cut .065 R/T on my second pass, but that run netted me a slower E/T and MPH.
Mods to date:
-05' RCSB 4.8/Auto
-Comp 206/212 on a 112 lsa
-Volant CAI, Shaner Ported TB, 180 T-Stat, Corsa Catback, Wheatley Tune
-Eaton w/ 3.73's
-Corvette Servo
Previous Best before cam, servo, and retune:
R/T ... .379
60' ... 2.375
330 ... 6.546
1/8 ... 9.991
MPH ... 71.97
1000 ... 12.925
1/4 ... 15.41
MPH ... 89.90
New Best w/ Cam/Retune:
R/T ... .380
60' ... 2.371
330 ... 6.470
1/8 ... 9.807
MPH ... 74.33
1000 ... 12.653
1/4 ... 15.035
MPH ... 94.67
.4 faster 4.77 mph improvement w/ just the camswap, not bad considering the size of the cam just seems like there should be more in it.
MPH seems like it should be good for a mid 14 sec pass, but Im a solid .5 sec away. I realize my 60' sucks which I can attribute to the stock convertor, but what gives? Is a lack of a convertor my only issue here? I'm sure LT's wouldnt hurt either, but my ET should be better IMO.
Let me know what guys think, any help is appreciated...
Old 02-22-2009, 10:30 PM
QLF
QLF's Avatar
You have the trap speed, but you're lacking a good bit in your 60', like you've already noticed, and your 1/8th E.T. is a little on the slowish side. A good stall should drop you around 3 tenths if you can hook and the LT's will help your mid range pull a good bit.
Old 02-22-2009, 10:43 PM
sonoma43's Avatar
amen to that!
Old 02-22-2009, 10:45 PM
GMCtrk's Avatar
shoulda kept the LTs that are now solidly attached to my cylinder heads
I think the obvious answer for you is bigger cam, stall, and LT's, and 4.10s/trutrac to put you solidly into the 13s...
Old 02-22-2009, 11:06 PM
regency's Avatar
weather (DA) worse?
another thing i can think of is heatsoaked MAF. did you sit in the staging lanes idling?
Old 02-22-2009, 11:16 PM
Agreed, 1/8th did seem slow to me as well. Seems it is gaining alot on the big end of the track, but lagging alot until the 1/8th
lol, I hear ya on the headers. Cam isn't going anywhere anytime soon, but some 4.10's and a convertor may be on the to-do list. Installed an Eaton LSD when I did the 3.73's so no need for the tru-trac.
Originally Posted by regency
weather (DA) worse?
On my first pass no, truck was probably at 160-170. Second pass was hotlapped so that is possible
-So the general concensus is the lack of convertor? What should my MPH be good for ET wise?
Old 02-22-2009, 11:44 PM
zippy's Avatar
Lack of converter for sure. Get that fixed and you'll pick up a good .5 or so and some more mph.
Old 02-22-2009, 11:59 PM
Truck Sponsor
Wheatley's Avatar
You really need a converter and it will run so much better
Old 02-23-2009, 12:07 AM
99Silverado5.3's Avatar
MPH is about right for your mods. It's that 60' that's killing you.
Old 02-23-2009, 12:22 AM
Thanks for the input fellas. Pretty much confirms my thoughts..... what do you guys recommend convertor-wise? Would I be wasting my time w/ anything less than a 3000 stall givin that it is a 4.8?
Quick Reply: Diagnose my Timeslip, Help Needed Inside
