dodge ram with 7000rpm rev limit
http://s136.photobucket.com/albums/q...t=IMGP0127.flv
We are finally able to increase rev limit to 7000rpm easily.
oh no.... Here is a quote from the engine builder:
"It's basiclly a 0.020" over 5.7 with a 6.1 crank thats offset ground to give a 3.795 stroke. I set it up with a 268 cam, Our big chamber 6.1 heads and CP pistons yeilding a 10.8 CR, I ported the intake and slightly ported the throttle body. Other than that it's pretty much a stock 5.7"
That is a comp cams HR268....
TJ
TJ
no, he has a 370 stroker with ported 6.1 heads, comp 268 cam, ported intake, stall, and alot of other things i dont care to type. his best time was a 12.78NA with the old rev limit and no weight reduction.
thanks & more to come
TJ i do not have the big valve heads , i do have the 6.1 cnc ported
i will not run without some kind of filter , spend all that money to suck something into the intake , not me
