drag tips
A guy I work with bet me 10 gallons of gas and lunch that I wouldn't run under a 14.50 right now I'm running a ecsb 5.3 with 10# and meth 2800 stall 3.73 gears ill pry run the stock 265s for tires or 33 mud tires its a 4x4 too any tips
Like use 4 wheel drive or auto 4 or just two wheel. Any ideas on what ill run. I'm shooting for 110 mph in the 1/4 so what ever that gets me hopefully 12s
Something is wrong if you wouldn't go faster then a 14.5 no matter how bad you spin. I'm not sure how the 4wd stuff works so cant help you there but depending on how the track is I'd think you should trap mid to upper 100s. Turbo or supercharged?
KickinAssAndTakinNames
i think most the 4x4 guys launch in 4 then hit the button before the 1-2 so that second gear and on is 2 wheel drive.
not 100% on that though....
also what TXsilvy said^^^^
I would strongly advise not using auto 4 wheel. Launch in 4x4 high and either say in all the way down or go back to 2wd after the 1-2 shift.
