ET street question
#32
![Angel](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_angel.gif)
#33
Baltimore Whore
Then if that is the case I would look for a FULL out drag slick.. A radial will prob be a harder compound.. If you go to the makers page I am sure there is a chart that shows what compound is used. Then all you have to do is find the softest one.. It will get sticky the fastest..
![Happy](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_stretch.gif)
#34
Then if that is the case I would look for a FULL out drag slick.. A radial will prob be a harder compound.. If you go to the makers page I am sure there is a chart that shows what compound is used. Then all you have to do is find the softest one.. It will get sticky the fastest.. ![Happy](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_stretch.gif)
#35
I have always been told that a DR usually needs a shorter burnout than a slick. I know that when I had BFG DR's on my Z28, longer burnouts ended up giving me less traction, similar to street tires. They worked best with just a short clean-up burnout.
That was about 10 years ago, and I'm sure that the new technology in the new DR's (and slicks) is better than it used to be. So I was looking for some "real world" experience from fellow members here before I make my decision.
Thanks for all your input guys. If anyone can add their experiences with these tires, it would be appreciated.
#36
Dude a ET street is a hookin *** tire. Spin the water off, dry hop once and your good to go. M&H are good too. But personally Et Street is the best bet. Plus its the fastest drag radial in the world right!
#37
Baltimore Whore
This is a fellow members truck. Saw this run in person a few times, on that run also.. It hooks dead, with the hoosiers..
http://www.youtube.com/watch?v=ihAinQfqIcY
#40
both are probably great tires.
Heres a Mt Et street. Just to show the capability
http://www.youtube.com/watch?v=if5dSwcSQkw
