fail.
fail.
Well had alot of fun at the track meet, but the truck didn't do so well, engine was making good power but had a problem with the converter or line psi in the Trans, the converter wouldn't hold any power it just flashed up and the rpm sat in the corner, it would flash to the shift point and go into second like 5 feet out then third like 400 feet out. So I had no top end and couldn't hook up at all! Best pass was 11.6@119, best mph was 121. Should of been more like 126-128 on the 19 psi. O we'll I'll get her fixed and try again.
Yep I'll be hooking up line psi gauge to it tomorrow (if you can) and make sure it's got full line psi, if it's the stall IM going to see if they will take it back, I'll eaither be getting a yank or circle d then. Mines a pro edge converter rated for 1200 hp it should take more all this
therock
08-20-2014 04:45 PM
01WS6/tamu
05-31-2014 05:44 PM
TJ95Tahoe
04-29-2014 02:04 AM
