Finally hit the 11's
blownerator
Originally Posted by hemidup
I run a Dodge Ram 1500 4x4 RCSB. Race weight is 5139#'s. The engine is a 6.1 SRT8 Hemi stroked to 6.4/392 cu in. Fully forged with 8.6:1 Ross pistons. Custom hand ported Sharadon heads and an FRI cam that is 216/220 .526/.531 with a 114 lsa installed at 110. 12 lbs of boost through a Paxton 1500 centrifical blower with the Snow Performance w/m dual nozzel system for cooling. I run a 50/50 mix. Duel stock 58 lb fuel pumps with 66 lb injectors regulated by a boost referenced regulator. 3.92 gears with 28" M&H drag radials on all four corners locked in 4hi for the strip. I use spring clamps for the rear and pulled the front sway bar off to help weight transfer. The transmission is one that I built myself with a 3700 stall Edge billet converter. Everthing else is stock and I run the truck in full street trim.
BROKE-aSS-BLAZER
10-13-2017 03:50 PM
