first time drag truck
Registered User
i realy dont know what #s i should shoot for. i was thinking around 13s with a truck thats so heavy. i plan on stripping as much weight as possible but i'm starting with 5500lbs. i have a small block already that i can bore and stroke, everything else is up in the air. like i said before this will be my first project that is this exstensive, so i'm trying to do my research before i wast money on parts that dont go together. i would love to through a bb in it but i have a sb i want to make use of. i realy just wanted some advise on what direction i should go with the engine for the best possible results with a heavy truck. (ie: should i build for mid range hp because of the weight, or build for top end.. is a 383 the best engine or should i go with a 400sb?) i know i want the most possible power so i do want to blow it. if i can get 11s i would be more than pleased.
Registered User
Banned
1 Post
he was talking about a sbc 454,r you wanting to go fuel injection are carb. i would try and build a 427 are 434 sbc ls base motor you can put a carb on it are stay fuel injection.
If it's your first project and it truly is a drag truck. Shoot for hitting high 11s. That's still not a bad number and it's slow enough that you won't have to worry about building a full suspension for it.
GMCtrk
07-17-2015 06:39 PM
