first time at the track and boom. killed 60e.
#24
Got my call from rpm.they said the Output shaft broke. When it broke, it also took out the new upgraded rpm 5 pinion planetary, 3-4 clutches and some other stuff. Since the output shaft was a stock one, I'll have to eat the bill.but they were nice enough to work with me on it. But billet shafts are going in now. Gotta pay to play. Part of the game.
#26
Yes. I am fixing it. Since it was a factory part that let go and nothing they did. Fixing it is way cheaper then a 80e swap. Now that there is no factory parts, if it does break again, its on them for sure. And when it does break again, a 80e swap will be under way. I won't dick with this 60e after this time.
#30
Here is the parts list to there level 7.
Media Blast Transmission Case
RPM Sleeved Input drums
RPM 3-4 Clutch pack
RPM reinforced sunshell with collar and bearing
*NEW Extra WIDE Heavy Duty double caged 29 element sprag
4L65/70E low roller clutch
Billet 4th gear servo
Transgo HD2 shift kit
*Billet 2nd gear servo
Carbon Wide band
Updated aluminum accumulator piston
Bushing kit
New shift solenoids
New wiring harness
New GM valve body spacer plate
GM 5 pinion planetary sets front and rear
300M Hardened Output shaft
*300M Hardened Input shaft
*Billet Pump Rotor
Billet Overrun Piston
*Billet Forward Piston
*2-3 HD Apply Valve
*QUICK TIME SFI Approved Bellhousing
*Deep Aluminum pan
RPM 3-4 Clutch pack
Carbon Wide band
Bushing kit
New shift solenoids
New wiring harness
*Billet Pump Rotor
*2-3 HD Apply Valve
*Deep Aluminum pan
