TIME SLIP DATABASE
First times ive made in a 1/4 ever
Old 07-21-2010, 10:55 PM
  #21
Wearin' da big hat
00ChevyScott's Avatar
Originally Posted by Phantom
he had 2.4 60' and on street tires...why you gotta bag on the guy?
It was a 2.1 60 ft
Old 07-22-2010, 12:10 AM
  #22
13 Second Truck Club
A Low Dime's Avatar
He should have been able to run 8.7 on motor......
His mph isnt even high to compensate for the slow 60 or spinning. IMO those times were be fine on motor, its almost like the nitrous didnt even work.
The converter is a tad small, but anybody else with those mods runs 8.5-8.9. Some even do that with less mods. Hell, ChevroletAllTheWay just sprayed a 150 with his 4.8 into 7.5 1/8th mile........
I wouldnt spray that truck anymore, something is wrong with the tune or the nitrous set up. Does it actually feel alot faster spraying the nitrous compared to on motor?
Old 07-22-2010, 12:45 AM
  #23
AJII's Avatar
Originally Posted by Black'Rado
yea the heat will kill your times....
i went when temps were in the 60s and ran the 8.8
then i went back with the cam and radials and in 90 degrees and ran a 8.8
once it cools off your times will drop, along with with more practice.
The track you run on isn't a true 1/4 mile either though is it?
Old 07-22-2010, 12:47 AM
  #24
Black'Rado's Avatar
no its a 1/8 mile and 60 short so its about .3 faster than most tracks
Old 07-22-2010, 11:14 AM
  #25
walledition's Avatar
well something was wrong for sure cuz 2 days after that it broke so i guees i´ll put a good converter on that thing and see what happends next, transmission will be on its way back to check it, and yeah it feels faster with the nitrous
Old 07-22-2010, 05:33 PM
  #26
Ph.D. in HUBRIS
custm2500's Avatar
Originally Posted by fastrt
yes it does. colder weather, and the same shot will net better numbers.
your times were ok, on a 150 shot you should see at least 12.5's even with your 20's.
Cooler weather will still help but not nearly as much. If you need verification look at a DA calculator and it will tell you that nitrous or FI motors change X and N/A motors change Y
Y will be a much bigger change than X because with nitrous you "bring weather with you".
Old 07-23-2010, 08:51 AM
  #27
Banned
litreddevil's Avatar
man u got it running strong.... afew thing to try next time out with street tires when u stall it that high let the truck roll out a little before ya nail it,it will make a difference. weather will make huge differences
Old 07-23-2010, 09:52 AM
  #28
11 Second Truck Club
fastrt's Avatar
but it still makes a difference. higher iat temps bring timing down, high ect temps bring temps down. and I am not crazy about the tune, may have a lot left on the table. timing = power even with nitrous. running 25* vs 20* on a hot day makes a diff on the jug.
Old 07-23-2010, 10:23 AM
  #29
thank you for the positive comments... i called yank and i´ll upgrade to an 3600 stall, i may take to tsp again and see if everything is ok with my tune, i pulled 6 degrees of timing on the run that i didnt mention b4
Old 07-23-2010, 11:19 AM
  #30
Fepony's Avatar
Those times sure seem slow for your mods.
Quick Reply: First times ive made in a 1/4 ever
