TIME SLIP DATABASE
Full bolt on 4.8
Old 12-08-2012, 01:52 PM
  #71
Twentyhurtz's Avatar
Originally Posted by outlawz2004
My ext cab 4.8 with 3.42s went 16.3 at full street weight plus my all my crap for work in it, spare tire, tailgate, steel wheels. With a k&N, longtubes, and wheatley tune, lighter aluminum wheels and some weight reduction it was running consistent mid 14s. Best of 14.4 but mostly 14.5s and 14.6s. With the same mods on tahoe 20s(heavy), it went 15.1 at street weight with the 3.42s. I put in 3.73s and a locker and that helped out alot, but never went back to the track. The 4.8s love low gears, that along with a higher stall will get it moving.
Curious, what was your mph when you ran the tahoe at 15.1?
Old 12-08-2012, 02:12 PM
  #72
outlawz2004's Avatar
not a tahoe, the tahoe 20" wheels(84lbs each with tires). I think it was around 92mph, I will have to dig out some old timeslips and check.
Old 12-08-2012, 02:59 PM
  #73
oh sorry, well that gives me and idea of trap speeds with these trucks.
Old 12-08-2012, 08:18 PM
  #74
GMC Sierra Run #1 (Bone Stock 4.8).wmv - YouTube
Here is my embarrassingly slow run. Gonna pull the 350 lbs or so off and run it again in a few weeks. Video may not be done uploading yet.
Old 04-10-2013, 12:47 AM
  #75
Driver311's Avatar
Originally Posted by bogues824
Hey guys new on here I got a question. I got a 2000 4.8 Silverado that I've had for a few months and I was thinking bout showing it some much needed love by putting boltons and 212/218 low lift cam, long tubes and exhaust, cai, pcm tune any ways long story short if I do all these mods to the 4.8 and then decide on swapping a 5.3 can I put everything from 4.8 to it oh yeah n if the 5.3 would run the same or better with the tuned 4.8 pcm also it is a daily driver.
My dads truck has this same setup. 00 rcsb, 3/4 drop, 4.8 with comp 212/218, pacesetter lt and ory, magnaflow muffler, ebay 4in intake, efans hp tune 91octane. Stock truck make 225whp and now sits at a solid 305whp. Truck flat out rips. Ran my buddies mid 13 second ecoboost the other day from 30-100 and pulled two lengths on him with the stock 3.40 gears. Truck will have yukon diff and 4.10 gears very soon. HOping for low 13s maybe even a 12.9 in it. Will post slips very soon. Hoping by end of month or early next. Dont doubt the lil 4.8s. They make decent power just lack the trq. In a light truck like my dads the motor works great. Fun lil revver for sure.
Old 04-11-2013, 08:38 AM
  #76
Ph.D. in HUBRIS
custm2500's Avatar
Unless D.A. will get better you won't see a 16.5 any time soon probably. 100 lbs is aproximatly one tenth. That isn't 100 correct either so youe 350 lbs might drop you .3 if you are very lucky.
I think this in one of the threads I already explained this but unless you are boosting the only way to not waist your time is to pull that 4.8 and spend your first $1000 or possibly way less on a real engine. A fully modded 4.8 that can be driven on the street is still slow. Look around and see better explinations and more proof. A 6.0 has nearly 100 hp and a lot more torque stock, then every mod will make more power for the same money. $1000 is mods on your 4.8 might net you 30-50 hp.
Old 04-11-2013, 10:43 AM
  #77
nonnieselman's Avatar
This thread is awesome!!!
Oh and if you dont want to give up on the 4.8, spray it. spray alot!
We had 250 on my buddys 300,000 mile 4.8 and it ran my times at the short track. stock 4.8, tr6 plugs, homemade CAI, trailblazer converter, 3.42s, 26" Drag radial. It went 9.4? at the local 500' track.. and a 6.7 on the 250 shot. My truck ran a 12.5@110 when it did a 6.7 at the local track.
We never got to try a 300 shot, his noids wouldnt flow enough.
But that thing was swift on the spray. So a 4.8 isnt a waste to mod.. if you mod it right. With heads, cam, converter and gear, it could have gone 11s easy.
Old 04-12-2013, 04:34 PM
  #78
Ph.D. in HUBRIS
custm2500's Avatar
Yea big spray helps too!
Old 04-13-2013, 01:00 AM
  #79
UnVmy5.3's Avatar
...... full off useful knowledge in here
JordanH
08-08-2015 07:59 PM
4B11T
07-13-2015 03:48 PM
NuckenFuts
07-09-2015 08:45 AM
Deceptarado
07-08-2015 05:24 PM
Quick Reply: Full bolt on 4.8
