gear change question
If you are just changing gears, and not tire size, I think it is going to hurt your 1/4 mile time pretty good. If you have the 285/70/17's on now, you should be crossing the traps at about 4600 RPM's in drive. If you switched to 4.10's, 99 MPH would be about 4100 RPM's in drive. If you switched to a 31" tire with 4.10's, you would be going 99 MPH at about 4400 RPM's. Give or take.
ive always been told you wanna cross at the same rpm you shift at. id like to try more gear. i think with your tire size your closer to a 4.10 gear. i run a 31'' tall tire on the street and a 28'' at the track. i think i cross at 5800rpms also,
Castro45
24
07-31-2015 07:13 PM
Dezert1500
07-30-2015 02:51 PM
