TIME SLIP DATABASE
Heading to the track tonight
Old 10-31-2008, 10:42 PM
2nd fastest 5.3 ECSB
trever1t's Avatar
Well? well? well?
Old 11-01-2008, 12:58 AM
KySilverado's Avatar
Well a new PB. Rolled right off the road. Tech'd and made a pass with the 50 shot.
11.710 @ 113.00. A 1.64 60'.
Track was busy. 4 hours later and a swap to the 75 shot. Temp had dropped to about 45. Hopped bad out of the hole.
12.06 @ 113 with a 1.88 60'.
No doubt in my mind if I could have made a couple more passes and a little bit of tuning with the 75, it had an 11.5 or .4 in it. With just the cool down and the 50 shot 11.6's or a 11.5. Anyway, mission accomplished. Confirmed everything is okay performance wise. Amazed I went a new best with a stock 65e and drove it home.
Old 11-01-2008, 02:17 AM
SimpleManLance's Avatar
congrat on a new best.
do you ever run run any times with out the nitrous? and are you still sporting the 5.3 or a 6.0
Old 11-01-2008, 07:35 AM
hemidup's Avatar
Congrates on the new best.
Old 11-01-2008, 09:46 AM
Thanks. I run more without the nitrous than with it usually. Just one goal last night test it and push it a bit. Sporting and 03 6.0L Lq4 now.
Thanks bro.
Old 11-01-2008, 09:59 AM
trever1t's Avatar
Ah Roger, congrats on the new best! Wheel hop? That 75 hits like a brick huh! What was your 60'?
Old 11-01-2008, 10:42 AM
Yeah it hopped hard out of the hole with the 75. Probably the first 20 or 30 ft then settled. Enough to screw the run up. I honestly couldn't FEEL a difference between the 50 and 75 shot. Ran the same MPH. It nosed down a bit at the 2-3 shift. Haven't looked at the logs but prolly went rich. I posted the 60's above.
I do see doing a 2-step or delay if I continue with the nitrous and 80E later. It won't take the full hit out of the hole.
Old 11-01-2008, 11:11 AM
trever1t's Avatar
my eyes suck...1.64 on the 50-shot :wow: is that your best 60' too? Wonder why you are getting so much hop?
Old 11-01-2008, 12:47 PM
Moderately Differentiated
dewmanshu's Avatar
Yeah holy **** on the 60' footer. WOW. Awesome run!!!
What size tires are you running? You running 4.10's?
I couldn't agree more on the 2 step.
Old 11-01-2008, 01:44 PM
Stiff suspension would be my guess. Doesn't do it in 2WD. Its' like it grabs, squats, breaks the front, grabs, squats, breaks front. A hard studder 4 or 5 times. Have you seen how pulling trucks will hop at the end of their runs sometimes.
Think a 1.62 is my best 60'
Thanks Dewey. Running 245/50/20 tires and 4.10's. If I could find some smaller wheels now that will fit over the brakes and a shorter DR all 4 corners would go a long way
Quick Reply: Heading to the track tonight
