TIME SLIP DATABASE
hemi truck runs 14.02 at 95mph in the 1/4
Old 12-14-2003, 02:59 PM
  #101
Registered User
Pro Stock John's Avatar
14.0@95mph sounds right if the truck is making 400 hp. for me to run that good in my 99 Tahoe, which has the same weight, I'd need to make hmmm I think 400 crank to get there...
Old 12-14-2003, 03:33 PM
  #102
Tokez420's Avatar
how do we know u dont have a stall, gears, head work **** like that?
Old 12-14-2003, 04:04 PM
  #103
h777's Avatar
2reaper......if you go back to DTW and look again there is my time slip of 14.02 i think its on page 9-10 go look it there 14.02 at 95.19mph in the 1/4 mile 8.87 at 77mph in the 1/8 mile with a 2.01 60ft
Old 12-14-2003, 04:07 PM
  #104
h777's Avatar
torkez.... there is no stall out for the hemi trucks yet and the gears are the stock 3.92....and no head work my motor has never been apart
Old 12-14-2003, 04:09 PM
  #105
14 Second Truck Club
onyx's Avatar
juice......... anyone? i have some left over oranges....
Old 12-14-2003, 04:19 PM
  #106
h777's Avatar
no juice needed everybody will be able to inspect my truck at the track
Old 12-14-2003, 04:55 PM
  #107
02Reaper's Avatar
I stand corrected. Good run man. You have a beast if you are telling the truth.
Old 12-14-2003, 05:18 PM
  #108
KeukaZ71's Avatar
Originally Posted by h777
pro stock john..... it was with the stock 17inch wheels and stock tires that are 245/70/17s with a 2.01 60ft
that is pretty good 60' times. usually with intake mod and exhaust, you loose a little backpressure and low end torque, but do better high end. is the hemi 2wd or 4wd, and what are you launching in?
Old 12-14-2003, 05:22 PM
  #109
KeukaZ71's Avatar
ah, just noticed that you had 3.92 gears. that might explain your 60' times. how are you hooking so good with stock tires?
Old 12-14-2003, 06:39 PM
  #110
h777's Avatar
keukaz71........my truck is 2wd i leave at 2200rpm tires set at 22-24 pounds and no swaybar....it helps alot with the 60ft
Quick Reply: hemi truck runs 14.02 at 95mph in the 1/4
